Thread: ECU question
Old 11-02-2008, 10:25 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
I believe that you are correct, 86.5-88 N/A ECU. You can use an automatic ECU to make it work, however you will have to do some creative wiring as the Reverse lights won't work when you put it in Reverse, and the clutch safety switch won't work. I believe there may be other issues, but I'm not positive on that
