Old 10-25-2008, 02:45 AM   #1
EthanMKIII
EthanMKIII is on a distinguished road
Originally Posted by Busted Knuckles View Post
Where did you find that one? I goggled it, and it is a 2.0L I6 engine used with less compression and power than the 7M-GE. Wikipedia did say some Supras used it. Wow. I doubt the 7M-GE plugs would work. The heat ranges must be different.
I located a Toyota spark plug chart, and the 1G-GE engine uses the same BPR6EY-11 plugs the 1988-1992 Corolla with the 1.3L 2E engine uses. Here's the chart.http://monroesamara.ru/files/europe.pdf
In japan there was no N/A Supra for the 89~92 Models it was ether the 2.5L TT 1jz-gte or the 2.0L Ge-gte TT
EthanMKIII is offline   Reply With Quote
