Thread: TEMS upgrade?
Old 10-20-2008, 06:19 PM   #1
Moy
Moy is on a distinguished road
You might also like to check out supramania.com and supraforums.com
Both are excellent sources of information for Supras, but as yours is a MKIII, I would highly recommend supramania as most of the members on there have MKIII's.
If you haven't replaced the HG yet, that could be something you'd like to look into. The OEM HG is known to blow because Toyota, from the factory, only torqued the head bolts to around 56 ft/lbs, where they should have been torqued to around 72 ft/lbs. Most people go with Stone HG or a metal HG, with ARP head studs. As for your suspension, if you would like to keep the option to use your TEMS, the Tokico Illumina shocks are the only aftermarket shocks that are TEMS compatible.
I'm just relaying to you what I've read and how I understand it, I suggest searching supramania for sure.
I hope this has helped at least a little bit.
Moy is offline   Reply With Quote
