Old 10-18-2008, 11:13 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
If you haven't done so yet, get the http://www.toyota-supra.info/forums/...9950-tsrm.html
I suggest you get access to air tools, especially a good impact wrench. The pinion flange bolt is a serious PITA without one. The factory torque setting is 134 ft-lbs. And yours has been on there for at least 13 years. It will not come off easily. Did you get a new spacer/crush sleeve? These are also suppose to be replaced when the pinion nut is removed. This guy is important to set the proper pre-load on the pinion bearings. Some shade-tree mechanics go ahead and re-use the old one, but most professionals say it is a No-No, and will lead to quick failure of the pinion bearings. I say, replacing it is cheap insurance. For the rest, follow the TSRM.
P.S. Air tools only to remove. Use a torque wrench to reassemble.
