Old 10-13-2008, 05:38 AM   #11
no more fart cans!
no more fart cans! is on a distinguished road
Default what???
The MK3 supra has McPherson struts in all four corners. and on the topic of sub frame connectors, you really have nothing to connect them to. if you want to eliminate flex then you need larger sway bars, a 6 point cage, and ACTUAL strut braces. That cheap crap you see in magazines and movies does nothing. Actual strut braces must be triangulated and have gussets placed on the bends for structural support. welding seams works as well and realistically for any other cars that you do put sub frame connectors on, remember one thing, bolt on sub frame connectors are absolutely useless. all the tension is applied to the bolts. If you want to modify a chassis the only way to go is welding and fabrication.
no more fart cans! is offline   Reply With Quote
