Thread: Engine stalls
Old 10-11-2008, 02:50 AM   #1
Kenny[NK]
Kenny[NK]'s Avatar
Kenny[NK] is on a distinguished road
I had the same problem. Actually still have. Check your power steering lines. Mine were leaking and causing the same problem. It's possible the pump is bad but more likely that the lines are bad. You can drive without power steering just fine but it will be harder to steer.
MySpace
MKIII
Kenny[NK] is offline   Reply With Quote
