Thread: bhg
Old 10-07-2008, 01:56 PM   #36
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
>"im thinking the shop took off just a little too much from the head and the compression is too high therefore blowing another gasket."<
Highly unlikely, especially if you haven't used full boost. I just reread this whole thread and didn't find any comments about it smoking before. What color is the smoke? Pull all 6 spark plugs and shine a small light into each cylinder. If you see any water, it's probably the head gasket again. If they are all dry, it's probably good. How much does it smoke? Maybe you can drive it thru the winter, save some $$$, and determine if the smoke is just valve seals/guides or rings/bearings. Worn rod bearings will throw a lot of oil on the cyl. walls, more than even good rings can handle.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
