Old 10-05-2008, 03:49 PM   #31
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 1993suprawr View Post
and i was planning on buying this for my car since i dont have any gauges in it Blitz SBC I-Color Electronic Boost Controller with LCD Display should i not worry abotu that stuff or is it okay to buy it and get someone to install it, or what other gauges would i need? or is this thing good enough...haha just thougth i would since it looks pretty sweet lol it shows like "- The color monitor can show 12 kinds of data, which are BOOST, TACHO, SPEED, POWER, TEMPERATURE (water/oil), OIL PRESSURE, FUEL PRESSURE, AIR/FUEL ratio and External Voltage Input 1-3 (needs optional external voltage input harness). Maximum 6 kinds of data can be shown on the screen at the same time. (Please note that temperature sensors, pressure sensors, and A/F unit are optional items.)" i donno just give me a heads up on what type of gauges i should go for and some links so i can buy some like whatever ones that are important, thanx
All you really need is a boost gauge, for most situations. If you're going to be your own tuning with a standalone ecu (or piggybacks), you could use a wideband O2 and EGT...
Life begins at 30psi.
