Old 09-26-2008, 06:13 PM   #1
CyFi6
Just the camshaft without any belts on it? Did you properly remove the head in the proper sequence and in multiple steps? Did you remove the cam properly and install it properly with a good assembly lube? If the head is warped too much the cam saddles can get out of alignment and stop the cam from being able to turn. You could also though, have valve issues.
