Thread
Transmission fluid check
09-22-2008, 02:09 AM
1
Busted Knuckles
The one on the bottom is the drain. The one on the side is the fill. It is considered full if a little bit of gear lube dribbles out when the plug is removed. If not, put a finger in the hole, and it should touch gear lube. If not, your low.
Busted Knuckles
View Public Profile
Send a private message to Busted Knuckles
Find More Posts by Busted Knuckles
