Thread: its new 2 me
Old 09-14-2008, 10:13 PM   #2
Chambers
Chambers's Avatar
If you have the capacity to weld then it may be easier and cheaper to just make a front facing intake manifold, with a larger throttle body.
If not then modify your current intake manifold to a front facing status, as in cut open the front side of it, then weld the old TB hole up and put a new flange on the front side of the manifold, that way you retain all your stock engine parts but have the front facing intake.
Good luck.
"Stuck in the 80's"
