Thread: need new clutch
Old 09-05-2008, 02:39 AM   #1
suprabahamut
For a clutch if you have a manual it helps the most. I have not done a clutch job yet on my supra but I have a place near me that does good work for pretty cheep. So I am going to them because of a warranty with the work. The only advice I can give about clutches is to put them in correctly with the engine side and the transmission side or it will be a tear down again if wrong. What is the problem first? It could be the clutch pedal needs to be adjusted as easy as that.
