Old 07-29-2005, 08:49 PM   #1
Poodles
Poodles is on a distinguished road
25: Air-fuel ratio lean malfunction (1988 and later California models only)
26: Air-fuel ratio rich malfunction (1988 and later California models only)
51: Air conditioner switch or neutral start switch
25 and 26 together, odd... maybe you're O2 sensor? 51 i dunno, maybe it was in gear, or soemthing else, I don't think I'd worry too much...
Extra oil is usually bad, as the crank is usually hitting the oil anyways at normal levels. This is usual though, the 7M-GTE might be different, though I'd like to see photos to prove it <_<
Sounds like your fog lamps where re-wired to work with the marker lights somehow, as I know mine won't turn on unless the low beams are on.
I don't have TEMS on my car, but I can only guess that the third light is the error light...
Poodles is offline   Reply With Quote
