Old 08-31-2008, 09:16 PM   #5
EthanMKIII
EthanMKIII is on a distinguished road
Originally Posted by CyFi6 View Post
There is no bleeder port on our cooling system
The radiator cap should be rated between 9-15 psi
If your hose clamps are loosening themselves up, your hose clamps are the problem not your hose. Dont use hose clamps anyways. Go get yourself a new radiator upper hose and buy some spring constant tension type clamps. Hose clamps totally fuck up hoses over the long run.
The hose clamps aren't loosing up the hose is sliding off slowly when the the engines hot. At first i was using the stock clamps then i switched to new ones either way the hose is still sliding off.
EthanMKIII is offline   Reply With Quote
