Thread: Troubleshooting
Old 08-30-2008, 05:26 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Durandal View Post
...Also on the way back I tried the cruise control. Pushed in the button the light came on and I clicked it down to set the speed and took my foot of the gas and it did not maintain speed. Is my cruise not working or am I missing something in the operation.
Try holding it down for a few seconds (i.e. not just a click)...and be sure you're over 40mph.
...*Edit2: After doing a lot of reading on many different supra forums I have come to the conclusion the speed signal is getting lost in the buffer that happens in the ODO. I'm going to touch-up solder all my connections on the ODO cluster tomorrow and see if it gets resolved. If not I will just bypass the buffer by cutting the pink wire as Phil has mentioned.
Um....my post above mentioned more than just cutting the pink wire, right? Either way, I'm glad that the ODO turned out to be the problem - hopefully my post (and not just the "many other supra forums" you read) helped you to isolate it.
Life begins at 30psi.
