Old 08-28-2008, 02:03 AM   #1
Grandavi
Grandavi's Avatar
Woot.. this car is just too much fun. I hope that wears off after a while before I start killing the car by enjoying it.
Those wires you mentioned seem to be from the sub. I think he has it wired directly to the battery. Those go.. cause they bug me (the wires, amp and sub).
The wipers and side moldings by the windows definitely get painted. But I think I may hold off a bit to see if I repaint the car. If I do repaint the entire car, I will be going custom and I have a design for a monarch wing style side paint that I may use. (if i get the time, I will add it to the char via photoshop as that is what I do for a living... (digital imaging specialist).
And now.. the engine compartment (this is kinda the scary area)
First a little background. I am not sure if this is the original engine. Its hard to tell from the repair bills. In Jan. 04 he paid 5000+ for the engine replacement/rebuild and 5 months later paid 3000+ to rebuild that (they had to regrind the crank and redo the rods.. so I am assuming he ran it dry). At that time he also replaced the turbo. Following all those repairs, his dad found out about his tickets.. so from that point on, he was on his own. (therefore, couldnt afford to drive it).
The engine repairs were done 22k kms ago (not sure what that is in miles... 10k miles??). Who knows how much damage he did in that time. But I do know its seeping oil somewhere and it may be the turbo... ah well.. lets look at what I could show on camera as i try to plan upgrading/repairing it.
All the pictures come below the comments:
The engine compartment (my troubles seem to be mostly on this side)
Now.. what the heck is missing here???
Now... I am assuming there is a trick to servicing this air filter (is that what it is?) Also, I read in other posts that this may not be the most efficient air filter to run, and if so, I would like to upgrade it. My main concern in this engine is longevity and fuel economy and power (in that order). (pic below)
Also, in the pic above... I have read about changing that pipe on the left side I think... but am not familiar enough with this engine yet. I understand downpipes and turbo cutoff valves etc... in my head, but when looking at the engine, I feel I have to identify each component/hose before I start anything. I remember seeing some diagrams of this engine so I will hunt those down. Any upgrade suggestions are appreciated!
Oil is below.. cant tell if its leaking or from someone missing when filling the engine with oil (this is the top of the motor towards the back of the engine compartment). Should I be concerned?
close up of above picture below:
YIKES... look at the engine pic below.. who could love their car and leave it like this??? (I plan to replace the hose, unless there is a nifty fix somewhere that is better than factory)
After an hour run with the car, smoke (not lots) was coming from the area that you see this wet hose at... Im not sure what the hose is for yet, but again.. how can people leave the hose alone when its that obvious? (pic is below)
close up of the above area in the picture below:
Oil Dipstick - now I see why that post is stickied... I have no idea how much oil is in the car!! (this dipstick is dry btw...)
Wet...
Finally... there is some oil (I think) in here.. but may be spillage from filling the engine with oil.. hard to tell without ripping off everything on top of the motor...
So, any suggestions will be considered seriously. I plan to perfect this car over a 1 year period.. step by step as I can afford. Overall, I want to keep the engine modifications/repairs under 4k.
Oh yeah... I have the original warranty book and drivers manual that came with the car in excellent condition. Was happy about that!
Thanks for reading!
