Old 08-21-2008, 04:38 PM   #3
killersupra
killersupra is on a distinguished road
Default speed sensor fault
be very carfull people that when mechanics not auto sparkys like myself work on your japanese alien space ship that you dont always listen to them when they say iam shure that its the fault when they really have no clue unless tested with the proper gear ,the main problem with the supra is it shits the second speed sender /sensor which is the odometer which yes sends another speed signal to all the other lovely ecus as it cleans the signal up from the source sig which is from the first sensor on the gearbox and if your odo is still counting it can still be stuffed and people who install speed cut defenders and butcher the wires are in for a treat aswell.its the pink wire from the odo that the signal is traveled apon and it will even cause your supra to run like shit at idle and you will never find the damn fault,if any more info needed just pm me but iam in oz so cant look at vehicals,
killersupra is offline   Reply With Quote
