Old 07-28-2005, 02:20 PM   #1
ddmcse
ddmcse's Avatar
my is at 40lbs under full torque
80 is not normal .. check to see if the oil filter is the correct size . if you use the filter spec'd for the n/a the pressue will be too low , i am assuming a filter thats too small will increase pressure
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
