Old 08-11-2008, 12:38 PM   #2
Chambers
Chambers's Avatar
Yes, check the search for a while, there is some good info in thar.
If you are serious about doing this, I may suggest you buy a whole front clip, that way you have all the stuff you need. Buying a front clip will cost more but may save you many headaches in the future.
I may also suggest you check Driftmotion Garage >> Welcome, they have done a lot of JZ work in MKIII Supras.
"Stuck in the 80's"
