Old 07-28-2008, 07:51 PM   #1
nzskate
nzskate is on a distinguished road
hey yup i have swapped to manual ecu and yup i want to bypass the neutral start switch i have a wiring diagram of the ignition wires to the neutral switch to bypass it i think i have to join the 2 wires from the neutral switch does any1 know? thanks for the help
I doubt the auto (PRND2L) dash lights are relevant after a manual swap, since I don't see them at all on my 6spd tt dash. However, you are breaking some new ground here, so I couldn't even say that for sure. About the only other possibly-relevant piece of info I have is that a lot of guys with aftermarket heavy-pedal-pressure clutches completely disable the clutch-depressed no-start switch, because keeping the havy-pedal-pressure clutch depressed while starting has proven to wear out the thrust bearings in the engine. In other words, you should be able to completely bypass the no-start clutch-depressed signal to your ecu (assuming you've already swapped to a manual ecu - right?)...
nzskate is offline   Reply With Quote
