Old 07-28-2008, 12:35 PM   #3
mkiiisupra
It is summer, and from what i understand, depending on where your at your engine needs to be pretty cold for it to use the CSI...
" If the temp outside is more than about 65* (maybe 55*) it won't allow the injector to come on, to prevent flooding. Also, even in a snow storm, after 12 seconds of cranking time, the switch will stop supplying current to the injector. (prevent flooding)" (taken from the cold start injecotor post in FAQ section)
I thought this was my problem as well turned out to be timing and my throttle posistioning sensor.\
Run a diagnostic i you havent
1990 Toyota Supra Turbo A/T
