Old 07-23-2008, 09:13 PM   #1
CyFi6
I am not talking about the clutch being new or not, it has to be in the proper adjustment and the fluid line, like a brake line, must be completely free of air, so you need to bleed it first to make sure its free of all air.
To check manual transmission fluid you need the car to be level, and you need to remove the fill plug on the transmission, the fluid level should be even with the bottom of the fill hole.
