Old 07-20-2008, 02:49 PM   #2
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
I might have found the problem I did the injector cleaner and carb cleaner in the intake, but it was still messing up so I started to pull the wires and plugs to take a look at them, see if the plugs revealed anything.
Everthing checked out till I got to the last two plugs. The spark plug wells where half filled with oil???? My valve cover gaskets are leaking AGAIN.
I replaced them about 8 months ago and stopped the leak. When they leaked last time it didnt cause my car to mess up, but I knew it would eventually so I replaced them and checked it every week for about 2 months with no signs of a leak. Im sure the day after the last time I checked it, it started leaking again. lol I hope this is it.
Oh and I had one other Q. When you adj the tps, do you set it based on how the engine runs or on ohm resistance. thanks
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
