Old 07-17-2008, 12:04 AM   #1
Busted Knuckles
Busted Knuckles's Avatar
Most likely a problem with the ignition stuff. When it is like this, open the hood, and look for sparks at the distributor and plug wires. I'd start with replacing the spark plugs, ignition wires, cap and rotor, you know, basic tune-up stuff, and see if that clears it up. If not, get the coil and ignition module tested.
