Old 07-06-2008, 02:22 AM   #2
robertsws
robertsws's Avatar
robertsws is on a distinguished road
did you pull the codes? Wouldn't I need a programmer to do that?
no you don't just read this, MK3 TSRM On-Line
this is your new bible, so to speak.
is there any smoke? if there is, what color? Yeah theres smoke, its your typical grey smoke as far as I can tell.
there's black, blue, and white/grey smoke, black is fuel, blue is oil, and white is moisture. your grey smoke could mean a blown head gasket BHG or if your turbo oil seal is shot it would be throwing oil into your intercooler which would result in moisture in your intake. this was my problem.
when you step on the gas does your oil pressure increase? Yes
this could be a sign of worn piston rings, which a engine with your mileage wouldn't surprise me. i would do a compression check on your cylinders, read here for that MK3 TSRM On-Line
is there oil in your intercooler? How do I check that?
the ic piping at the bottom of you intercooler. remove that and see if any oil drips out
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
