Old 07-04-2008, 06:36 PM   #1
Chambers
Chambers's Avatar
I would go for a 2mm anyway for a turbo application, the 1.2mm will up your compression a little bit but I cant see it holding up to higher psi. As toneloc87 2 said, it dose depend on how much metal is taken off the block and head as well.
My preference is HKS for a MHG, but its really up to you.
Good luck.
"Stuck in the 80's"
