Old 06-24-2008, 11:15 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jslice13 View Post
so does it end up being worth it importing a supra rather then buy it here if its just for mere fact its a right handed import? because to do the bpu would you have to get 'import specific' parts? also i think i read that the turbos (or something im not sure) were made of different material? if this is the case is it possible to use parts not imported on the supra? or would i have to basically import everything both cosmetically and mechanically?
Yep the turbos are ceramic, which makes them slightly less durable, iirc.
Are you trying to convert RHD to LHD? If not, most 'bpu' parts for a LHD US-spec Mkiv Supra TT will fit a Japanese-spec Mkiv Supra TT.
Life begins at 30psi.
