Old 06-23-2008, 01:20 PM   #2
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
>"My ps pump has been flushed twice, makes no noise whatsoever, and turns effortlessly while standing still. Could it still be the pump?"<
Assuming you mean the pump pulley turns effortlessly and not the front wheels, it sure sounds like the pump is shot. Try a pressure gage test on it. You should get ~1,000 psi when you turn the steering wheel hard left or right.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
