Thread: Help me please
Old 06-14-2008, 02:21 AM   #1
TomFraser
TomFraser is on a distinguished road
Originally Posted by Zprodo View Post
I am very inexperienced with fixing cars, but recently I have run into a problem with my Supra and I was told that I might have a cracked head and/or cracked block. I was wondering if anyone could walk me through a step-by-step process of removal of the head or if someone could tell me of a site that addresses this issue. Thank you.
I recomend checking out
http://www.toyota-supra.info/forums/...-symptoms.html
as this is more common than a cracked head/block
If you don't have those symptoms and preferibly do a compression test then I would recommend using:
MK3 TSRM On-Line
to find out where everything is you need to remove
then look at
http://www.toyota-supra.info/forums/...s-rebuild.html
for an idea on what needs to be done when removing the head
TomFraser is offline   Reply With Quote
