Old 06-10-2008, 03:17 PM   #1
TomFraser
TomFraser is on a distinguished road
Originally Posted by TomFraser View Post
THANK YOU... It was the illumination warning... I will be hunting down the problem tonight
So... the idiot owner before me decided it would be a good idea to use the supra to tow a uhaul trailer, I took off the back left panel inside the trunk and saw the trailer attachment wires (badly connected) and didn't want to bother unconnecting, and also saw a yellow box that said "Lamp Failure" I unplugged this yellow box and will have no more issues with the warning light, however I have to check the lights every now and then because I no longer have that feature.
EDIT: Just making sure I was clear... to disconnect the system, cut the yellow wire going into the yellow "Lamp Failure" box, DO NOT UNHOOK THE BOX AS THIS WILL MAKE YOUR BRAKE LIGHTS NOT WORK!!!!
TomFraser is offline   Reply With Quote
