Old 06-09-2008, 05:33 PM   #1
supradaddy0803
supradaddy0803's Avatar
I will try to find a pic of it. It is a mechanical cable that is keyed at the end that goes into the tranny. The reason why it breaks it because of the turn put on it and the fact of it getting dry. Just remember to lube the cable by putting a little oil behind the connection before the pig tail and the movement of it will carry the oil up.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
