Old 06-09-2008, 02:45 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 2jz conquest View Post
From what I've researched so far, you need to drill out parts of the block for the studs to fit, is that accurate?
No. The threaded holes for the head studs are exactly the same in the 2jz-gte and 2jz-ge blocks.
If this is true, is the same modification required to fit a 1jz head on the GE bottom end?
Sorry, I have no idea about a 1jz head.
What part of the GTE pistons won't function in a GE block without squirters?
As you already alluded to in your next question, it's the cooling.
Would I have to worry about overheating the pistons without squirters
Honestly, it depends how much boost/hp you're planning to run.
or are stock GTE pistons forged?
Toyota hasn't released the metallurgy for the oem pistons...but it's a well-tested/proven fact that, with together with the oil squirters, they will handle 1100+rwhp through a 6spd (using aftermarket connecting rods... Fyi,the oem 2jz-gte connecting rods are 'only' proven reliable to about 850-900rwhp through a 6spd).
Note - I'll be out of town for a few days, so pardon the intermittent responses...
Life begins at 30psi.
