Old 06-07-2008, 10:31 PM   #1
supradaddy0803
supradaddy0803's Avatar
Kinda real hard to tell seeing as it is really squished in between the head and the block right now. If you have good compression right now and you arent having over heating issues or seeing water in your oil. Then I wouldnt really worry about it. Only when you start to see problems then I would start getting all the parts together. Well there may be one way if they did replace it and did it the best way by adding ARP studs then you will see the nuts in the head bolt holes. If you see the allen head bolts then it may or may not have been changed because if the dealership does it they will replace it with the slock head bolts.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
