Thread: Running Hot
Old 06-03-2008, 07:14 PM   #19
supradaddy0803
supradaddy0803's Avatar
Well as for a new motor you could get a 40k and drop it in but might as well do the head gasket when it is out and then drop it in. Other than that you could just upgrade like I did and get rid of the head gasket issues all together. But seeing as your having a mechanic do your work then I would say a upgrade would be out of the question seeing as the labor itself would kill you. But as for motors you can get a 40k 7mgte for like 700 bucks so I dont see how that is a ton more money. Plus look around you there might be a person from here that would be willing to help you do your HG and save you some money.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
