Thread: Fuel injectors
Old 07-21-2005, 11:14 AM   #1
ddmcse
ddmcse's Avatar
maybe the guy means the electrical connector to the injector is cracked in half .
you are supposed to pull the EFI fuse while at idle. i did that once
ofcourse i didnt do it like twice and i don't recall much difference . you are gonna see gas dripping, should not be a surprise . it's not like gallons of gas with 30 lbs of pressure are gonna come flowing out when you loosen the rail hardware .
btw does the A/C work now ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
