Old 05-30-2008, 04:06 PM   #1
supradaddy0803
supradaddy0803's Avatar
Man do like I did and buy a one peice one they are so much easier to put in and take out. Unless you dont have a turbo then you may have a hard time finding one for a W58 and not the R154 like most of them are made for. As for your brakes dragging I would take a look at how everything is set on the rotors themselves. See if when the wheels are in the air if the rotors turn smooth or if they make the grinding noise. You may also need to check your wheel bearings, if they have play in them then it may be grinding when you have weight on them. Mine were like that and it sucks doing them as well but well worht the effort.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
