Old 05-29-2008, 01:55 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Jaylyons1 View Post
...does the value go up at all if I swap it for the TT 2JZ-GTE Motor and Trans? I know I can get one for about $2k so was wondering if it would be worth it.
You'd need to swap several other items, including the ecu, ignitor, resistor pack, fuel pump ecu, driveshaft, and the primary wiring harness, just for it all to become functional. After all of that, the value would go up some, but it wouldn't be even halfway to TT's value, because the braking system (calipers, rotors, abs valving, abs ecu), suspension, rims, stereo, diff, etc. (and of course, the VIN) all still wouldn't be tt spec.
Life begins at 30psi.
