Old 05-28-2008, 04:01 AM   #1
mrnickleye
mrnickleye's Avatar
Unless your radiator is cracked (and you can see it), then first have a block test done to see if the headgasket is bad. Or if they do smog tests there, they can 'sniff' the radiator at the open can during idle to see if HC's are present,= BHG.
