Old 05-27-2008, 04:35 AM   #2
KingCobra
KingCobra is on a distinguished road
OK, gotta love internet troubleshooting!!! LOL
Motor is turning over...
Fuel Pump is working...
EFI Fuse good?
Ignitor is working and sending signal to the coils??? (should have constant 12v to all coils if the ignitor is working). Also help to plug in a noid light to see if you are getting pulses from the ignitor...
Main relay has been checked??? (you can usually swap this relay out with the a/c magnetic clutch, as they share the same relay).
Circuit opening Relay good??? (IIRC this uses the same relay too).
Timing Belt jumped timing??? (not likely but could cause this too).
Although in an unmodified car, these should never be issues, but you might still wanna check these, look at the neutral start switch, and the theft control computer. God forbid if a previous owner didn't know what they were doing wiring something into the car, these could cause problems too.
Just some ideas, suggestions to look into! I could come up with more but these are some things I could quickly think of. Good Luck!
Curtis
89 Supra (BHG)
93 Camry V6 SE
92 Cressida (1JZ-GTE)
94 Supra TT
KingCobra is offline   Reply With Quote
