Old 05-22-2008, 04:14 PM   #1
supramacist
supramacist's Avatar
That's one huge air leak.
I have had my n/a do this trick of yours.
For me it was a timing and cam position issue.
You can check vacuum leaks with a can of starting fluid.
Start the car let it idle and hose all the connections down with starting fluid. If you hit a leak you will know because the engine will idle up.
I hope this helps.
