Old 05-22-2008, 03:41 AM   #2
supramacist
supramacist's Avatar
The way I understand it is the w58 will work with the 2jzge.
If you have an r series trannt, you only need a bellhousing.
I hear the harness's are very close you're stock should need minimal modification.
You would also need jza80 mounting brackets an an 89+ crossmember.
