Old 07-20-2005, 11:15 AM   #1
ddmcse
ddmcse's Avatar
error code 12 and 13
RPM signal (crank angle pulse)
No Ne or G signal to ECU within several seconds after engine is cranked
1. distributor circut
2. distributor
3. Starter signal circut
4. ECU
glad i never looked for the sensor
on a turbo the CPS is right behind the brake fluid container bolted into the head ( on left hand drive ones )
on a N/A dont remember if it's the same place , but it's a distributor
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
