Thread: head bolts tool
Old 05-11-2008, 08:31 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
10mm allen key wrench socket (the longer the better) Make sure you locate the 10mm Allen wrench right to the bottom of head bolt (clean out any muck in the bolt head first) and keep it as vertical as possible, you will need to turn the cams to gain access to four of the bolt heads depending how long your wrench is. Before you do anything make sure the block is drained of coolant.
