Old 05-06-2008, 01:58 PM   #2
j3pz
if you look at the pic i posted before you will see that the one port blocked off would goto the bvsv on the thermostat housing (i dont know if you fellas in the uk have this, that would explain it being blocked off). as long as you have all the connections right, you dont need to use those metal lines. personally i see them as more possibilities of a vacuum leak.
edit: from your pics it looks as if someone tried to elimnate the use of the metal lines.
