Old 05-01-2008, 09:18 PM   #2
supramacist
supramacist's Avatar
DRY FLOW FILTERS Gents.
I like to dis-connect both terminals for atleast 15 minutes to make sure that
The battery and the ecu have both had ample time to adjust.
It's like re-booting your pc. Sometimes you need to leave it off for a spell.
That's about the going rate here in the states for a reman'd vafm.
You should also check your timing.
Keep checking for codes. Don't idle up or you'll automatically throw a 51 and that'll be your tps.
