Old 05-01-2008, 06:08 AM   #1
supramacist
supramacist's Avatar
It scares me that you said you just slapped a gasket on it and whatever other things you rambled on about.
You did this yourself or payed to have it done?
Was any machining involved?
You'll be lucky if you didn't just scrap your engine.
EDIT: anything that requires oil as a lubricant. can NEVER come in contact with coolant.
why? because oil will never bond to that surface after coolant touches it.. if its on top of your piston.
its inside your cylinder walls.
