Old 04-29-2008, 09:26 PM   #1
Mark's MKII
Mark's MKII is on a distinguished road
ASSUMING..... everything worked correctly before you put the new clutch in, then it sounds like a weak pressure plate. If everything was not working correctly then it could be master or slave cylinder, or just air in the lines. Where did you get the clutch assy and is it new or remanufactured?
7MGTE
Mark's MKII is offline   Reply With Quote
