Thread: Electric Fan?
Old 04-29-2008, 08:29 AM   #4
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
Originally Posted by sd88supra View Post
It doesn't take rocket science to figure out that electrical energy can be obtained much more efficiently than mechanical energy (ok, but does take a little bit of physics). Electric fans is the way to go. It is much more efficient to power a motor via an electric current than a mechanism. Electric fans will get you more air flow with a lower energy requirement. It will take this energy from your battery instead of your gas, so be sure to have a good battery. And you don't need to be an electrical engineer to install them. The circuits are not complicated (reading instructions SOMETIMES helps).
Oh by the way, 6 of one half dozen of the other, your battery doesn't just make voltage, its supplied from the alt. and that gets its energy from the crank and the rod to the piston taking power and gas milage. It would probably be more efficient but still pull power and gas milage from the motor
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
