Thread: Electric Fan?
Old 04-29-2008, 06:27 AM   #1
sd88supra
sd88supra is on a distinguished road
Default electric is the way to go!
It doesn't take rocket science to figure out that electrical energy can be obtained much more efficiently than mechanical energy (ok, but does take a little bit of physics). Electric fans is the way to go. It is much more efficient to power a motor via an electric current than a mechanism. Electric fans will get you more air flow with a lower energy requirement. It will take this energy from your battery instead of your gas, so be sure to have a good battery. And you don't need to be an electrical engineer to install them. The circuits are not complicated (reading instructions SOMETIMES helps).
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
