Ok, thanks for the help. I think I found and knocked out the main problem of no power to the ecu or B+ in the diagnostic port. It turns out the IGN 7.5 amp fuse in the driver under dash fuse pannel wasent making good enough contact in the socket so I bent the blades a little so now it fits snug. So check engine light is back on and working and now i have power at B+ and at the ig sw at the ecu. I also have 10.8vs at the fuel pump while cranking, so I guess that means I have fuel going to the motor. My problem now is that I still have no spark.
